Page Error 404
Page Error 404
Is it me, my connection, or a DNS issue, but it seems like very 4th page I get an error 404 page not found on ANY sites I visit.
ta
Dave
Page Error 404
If you get 404, then it is page not found.
DNS and connection issues can be ruled out.
404 is being return by the server, sugesting that a connection was actualy made.
You could check that you are not trying to use a proxy or other intermediate connection. On top, you should check that there is no spyware on your system.
Do you, or have you ever had a popup blocker?
Mike_Grice
Page Error 404
I'm in total agreement with acarr here - I would guess you're using a proxy. If you go to tools, then internet options in Internet Explorer, then access the connections tab, there is a LAN settings button. Click this, and ensure that the use a proxy server for this connection is not checked as this will most likely disrupt your connection and cause the 404s.
Just to recap what acarr said, a 404 is actually not DNS-related and will be generated by the server you're visiting. As a proxy fetches the pages on behalf, it will send you a 404 if it can't find the page. As the likelihood of you clicking on lots of broken links in a row is slim, I would suggest you're using a proxy that is broken somehow.
Page Error 404
Mike certainly likes his bold text on this thread Smiley
Chris
