PAP2 Help
PAP2 Help
Hi
I have got a pap2 and have managed to set it up ok and can ring out and make calls.
When people receive the call the volume that they hear is not as loud as a usual phone, is there any way to increase the outgoing call volume?
thanks
Cecil.
PAP2 Help
I think I have solved it myself by increasing the setting FXS Port Input Gain in the pap2 settings.
Cecil Cheesy
maccoylton
PAP2 Help
what settings did you use on the pap2 to get it workign with PlusTalk, in particular do you use NAT?
Thanks & Regards
Dave
PAP2 Help
yes NAT is enable
stun server set to yes
and the stun server is set to stun.sipgate.net
sip port 5060
proxy and outbound proxy sip.plus.net
use outbound proxy yes
Display name whatever your plusnet userid is
Userid and authid whatever your sipnumber is
remember if you have it set to make sure your router forwards port 5060 -5061 to the pap2 ip address.
hope this helps.
Cecil.
