P2P agent
madswitcher
P2P agent
Hi All,
What do people use for P2P activities? Is there one that can be used to time sequence so that I can take better advantage of the off-peak time and lock it out during the peak period?
At the moment, my son is using BitTorrent and I would like someting more PN-friendly.
Thanks and regards, Mike
P2P agent
Azureus with the speed scheduler plugin does everything you want. This is a java based client and you also need to install the sun Java runtime software.
madswitcher
P2P agent
Thanks Peter
I'll give it a try.
Regards, Mike
p.s. Where do you get the speed shedular from? Is it included?
madswitcher
P2P agent
Ah, foget the ps. I just found the site and plug-ins
thanks once more
Mike
P2P agent
You download it from within Azureus. Plugins -> Installation wizzard -> listy from sourceforge -> select the ones you want etc etc
