Outlook
Outlook
A friend has just e-mailed me, she has had viruses etc and has now run all the usual programmes.
Now she says that the
message that comes when I disconnect. Says "corrupt message received - no terminator"
Does anyone know what this means regarding outlook?
(She cannot send or receive messages, but says her settings are OK)
Cheers
Outlook
that will teach her to use outlook not thunderbird or another lighter mail client, but anyway.. tell her to copy the message in its entirty into google wtih " " around it, search for it, and im sure she will get an ans better than any of us can provide. (probably from microsoft.com (yay for help they give))
Outlook
Of course I googled it first! - there was only 2 results and they both pointed to the same page, which didn't give an answer.
I thought I'd ask on here in case anyone else knew the answer.
And before you tell me to go elswhere, as yet I haven't found it on microsoft.com.
Outlook
see if she gets the same error with a different client (thunderbird / bat / etc) if she does, its a setup issue that she has her end.
Outlook
Thanks for the reply - I think it is sorted, I keep trying to get her onto Thunderbird, but you know what people are like.
_ I still don't know what was wrong, but after running a lot of antivirus etc. progs- it is all working again.
