Outgoing email problem
Hi
I've setup adsl on a a new pc and configured outlook express.
I'm getting incoming email without any problems but its refusing to send outgoing...
An unknown error has occurred. Subject 'test', Account: 'PLUSNET', Server: 'relay.plus.net', Protocol: SMTP, Port: 25, Secure(SSL): No, Error Number: 0x800CCC0B
Is this me or plusnet??
Aaargh!
Can you confirm that you are connected through a PlusNet adsl or dialup account?
And do you have your "from" address set correctly in OE? (This can sometimes cause problems).
Do you have any firewalls / anti-virus software running which could interfere (this includes Windows Firewall)?
Using ASDL,
Windows firewall is not active and there isn't another firewall running either..just Norton virus software.
The from box in OE looks fine to me.
The most likely cause of that error message is that the sender's email address is set incorrectly (missing @ or to many dots etc)
If that doesn't work, most have found that it is better to delete all the OE settings and start again.
If you search this forum using the error code, you will find a few threads on the subject.
painswck
Not that familiar with Outlook. The error message suggests that the error relates to authentication to Plusnet's SMTP server.
Have you got authentication turned on in the settings somewhere?
Searching Google for that error code comes up with lots of references.
Roland
Muppet of the year award for me.
The email address I had in the 'from' box had two letters transposed.
Sorted!
Thanks for the suggestions.
