Outbound caller ID
Outbound caller ID
The calls I make via PlusTalk to landlines and mobiles present 'Withheld' caller identification information. This prevents me from making calls to land lines using Anonymous Caller Rejection (ACR). Can I configure this to present my PlusTalk 0845 'local rate' number? or if not can it more correctly (in this case) use 'Unavailable' outbound caller ID which I believe will not be rejected by ACR?
Best regards,
Andrew
Outbound caller ID
I'd be interested in an answer to this too. I've got a Linksys PAP2 ATA and everything works fine apart from CLI. It works fine on Sipgate though so I don't think it's the hardware.
Outbound caller ID
This is a known limitation with the current PlusTalk system but there has been no indication as to whether it can be made available or not in the future.
Outbound caller ID
When I asked this back in October, the reply I had from Stew was:
at the moment we do not own the range of numbers so legally cannot display them but we are working on this to see what we can do
Tim
