Oulook express issue
My outlook express wont delete my mails, it started today that i cant seem to have delete any mails, i trtied clicking on the icon but now luck.
I compacted my messages yesterday, could this be the problem
Using OE is a problem, download thunderbird and use it.
http://www.mozilla.org/products/thunderbird/
but anyhow no,. compacting messages wont be the problem.. when you say wont delete.. do you mean localy or from server or from both?
i cant delete it from locally, i been using this for years it started just today.
What actually happens when you try to delete your messages? and do you mean from the delete bin, or from within the inbox or a folder.
lowry
You could try checking your Outlook Express options menu (tools>options) to check that you haven't inadvertently changed anything. Have you installed any software since the problem occurred? Spam Filtering software that integrates with Outlook Express for example?
matt Wink
ive installed nothing
i cant delete from my inbox, i just click delete button or keyboard or mouse right click, and nothing happens.
Can you send and recieve messages ok though?
yep everything is running ok just i cant delete.
This inbox, it's not a hotmail inbox is it?
And you don't get an error message when you delete, it just doesn't work?
Nah i got 4 inbox in one, ones plusnet, ones hotmail and two my personal domain. Ive started using thunderboard now. I think ill try reinstalling it.
I've just been looking at the microsoft site, and that's what it suggests as well.
Sorry I couldn't be more help
Thats ok, cheers for your help
holdtight
Ive seen this before and the solution that fixed it was to create a temp folder anywhere "my Docs" will do, then move all the dbx files that outlook express has stored into the temp folder you created
restart OE then close it down and restore all the dbx files back to where they
came from
to find them start OE go to tools options maintainence click on store folder
and this will give you the path to the dbx files
dont even begin to ask me how or why this worked but it did, i cant gaurantee
it will work for you but its worth a go
yay for thunderbird.. dont look back Smiley
holdtight
Agreed !
