Offline
gilleyman
Offline
Hi, since moving to plusnet I have had an ongoing problem with my computer going offline, say I close Outlook Express it cannot find a connection until I press the try again button, the same goes for Internet Explorer, it's not a major thing but is very annoying each and every time I try to connect.
Is there something you tech buffs can recomend I try to fix this.
Regards Arthur
[/img]
Offline
Hi
In internet explorer, go to tools menu and select internet options.
Got to connections tab......check which option you have selected.
for example: never dial a connection
gilleyman
Offline
Yes northants10 I do have never dial a connection checked, and I have no connections showing in the window,all the options are greyed out.
Regards Arthur
Offline
Hi Arthur
Try to add a connection (it doesnt matter about correct username and passwords as you wont use it, or even phone numbers etc, just make them up) in this connections tab, and select it as the default connection.
Then check again that never dial a connection is checked.
Restart the PC.
Does it still do the same?
