OUTLOOK EXPRESS
OUTLOOK EXPRESS
I have just set up my e mail to recive mail in outlook express i can recive and send them fine but when i go to view a email i have recived it will not show up just blank page is there any settings i must set yo fix this or ant ideas y it is not showing up cheers all :?
1 REPLY
OUTLOOK EXPRESS
How are you retrieving your emails ? POP3? IMAP?
I have found in the past that if you retrieve your mail using the IMAP method, you have to wait for the message to be downloaded before you can preview it in outlook express.
