OE View Message Source
thekitesociety
For some reason the view message source button in OE no longer works. When the buttoon is pressed nothing happens whereas it used to open up the source of the message.
I have tried the tricks to solve this that I found on the web (clear temporary files, compress and clean up OE) but nothing works.
Also tried a re-install but again no joy.
So, any ideas?
Don't have a solution for your problem but if you highlight a message and press CTRL+F3 does it show the message source?
uninstall it... use thunderbird.. and there you go
