Now I'm confused...
Now I'm confused...
If I do nslookup on www.solstans.co.uk I get :
Non-authoritative answer:
Address: 66.45.240.146
Aliases: www.solstans.co.uk
Good so far...
But when I do traceroute I get:
tracert www.solstans.co.uk
Tracing route to cgi.plus.net [212.159.3.3]
over a maximum of 30 hops:
1 16 ms 15 ms 1 ms 192.168.0.1
2 21 ms 20 ms 20 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 20 ms 20 ms 20 ms ge1-0-0-204.ptn-gw2.plus.net [84.92.3.106]
4 20 ms 21 ms 20 ms gi5-0-22.pth-gw2.plus.net [212.159.4.5]
Not good... the same happens after doing the usual ipconfig /flushdns.
After rebooting my router the same still happens.
My router (DG834) is configured as a dns server but returns the right answer.
Windows is doing something screwy - and my hosts file is empty bar 127.0.0.1/localhost.
HELP!!!
Now I'm confused...
I take you are after :
1 1519 ms 2 ms 1 ms 10.10.10.1
2 182 ms 172 ms 110 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 29 ms 25 ms 25 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 234 ms 36 ms 26 ms gi5-0-22.pth-gw2.plus.net [212.159.4.5]
5 188 ms 145 ms 224 ms 195.47.243.185
6 145 ms 131 ms 98 ms pos8-0.gsr12416.nyc.he.net [216.218.200.101]
7 361 ms 272 ms 274 ms gige-g5-0.br1.nyc2.he.net [216.66.0.2]
8 348 ms 275 ms 272 ms 222.41.66.216.in-addr.arpa [216.66.41.222]
9 248 ms 276 ms 274 ms 64.20.32.66
10 303 ms 271 ms 274 ms gandalf.anonymousservers.org [66.45.240.146]
Trace complete.
Now I'm confused...
Yep, but rebooting my router, clearing my local and router's dns cache etc still give me plusnet's cgi server Sad
Now I'm confused...
poke CS they may be able to help
holdtight
Now I'm confused...
This certainly is a strange one solstans
im confused too are you any closer to an answer yet ?
1 26 ms 19 ms 19 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
2 19 ms 18 ms 17 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
3 18 ms 17 ms 18 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
4 23 ms 24 ms 23 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
5 23 ms 23 ms 26 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
6 26 ms 22 ms 25 ms cgi.plus.net [212.159.3.3]
Now I'm confused...
I disabled and reenabled my wireless nic and hey presto it worked.
Just checked and its gone again:
> server 212.159.13.50
Default Server: pth-cdns02.plus.net
Address: 212.159.13.50
> www.solstans.co.uk
> server 212.159.13.49
Default Server: pth-cdns01.plus.net
Address: 212.159.13.49
> www.solstans.co.uk
Address: 212.159.3.3
Only 212.159.13.50 gets it right...
holdtight
Now I'm confused...
None get it right here, if you ping your site it takes it through 212.159.3.3 everytime and a traceroute using www.solstans.co.uk still gives the below result
1 18 ms 18 ms 17 ms lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
2 19 ms 19 ms 17 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
3 20 ms 16 ms 18 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
4 23 ms 26 ms 24 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
5 24 ms 23 ms 25 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
6 31 ms 36 ms 29 ms cgi.plus.net [212.159.3.3]
Trace complete.
