Nominet Opt-Out
grahambritten
Nominet Opt-Out
Staticweb
Just a bit of additional info for you. In November my £1 co.uk domain name was renewed by PlusNet. For some reason after renewal my private address was being displayed when I did a whois at Nominet.
All I did was to raise a ticket and asked PlusNet to:-
... please inform Nominet that "The registrant is an individual who has elected to have their address omitted from the whois database".
It only took a couple of days to sort out with Nominet.
Hope this helps.
Nominet Opt-Out
Just a quick one...
I have a .co.uk with PlusNet, I would like to opt-out of having my address shown on the Whois database, how do I go about this? There doesn't seem to be an option on the site.
I have a hosting account with another provider to and it's just a little tick box on that.
Please help.
Nominet Opt-Out
I am not sure this is possible through PlusNet, once the domain is registered, though it can be done during the signup process.
I suggest raising a ticket on the issue.
If they are unable to help, there is another way around.
Nominet send you a registration confirmation letter, allong with a peelback strip, containing a code to access Registrants Online
Via this system, you can turn the Opt-Out on there.
Nominet Opt-Out
Thanks for that.
(Not sure where I put the certificate .. I'll have to go hunting lol)
Nominet Opt-Out
Yes, just raise a ticket.
Maybe a helpful extra piece of information: you can only opt-out if your site is non-commercial and, in my opinion, they have a very narrow definition of this. For example, having Google ad-banners on your site apparently qualifies it as being commercial.
--> Stephen
