Nokia E65 Phone . Anyone got it working with Plus Talk
Hello
I have a Nokia E65 Mobile . It works Ok with sipgate.co.uk which is free to sign up with. I can not get it working with the plus talk settings to use up my free minutes.
Has anyone out there got plus talk working with the E65?
Hello,
I am keen to see that you got the e65 working with Sipgate. I have one of these e65's coming and would also like to get it working with plus talk as I also use this service as well as Sipgate. I am sure I will be in touch!
Did you manage to get it working though with plus talk?
Cheers,
Si.
No still not got it working with Plus Talk. There was a solution from another post but it did not work for me Sad
I will keep looking in case you get back in touch.
Still no luck then? I can't get it to work but sipgate and voipcheap and truphone all work fine.
Cheers,
Si.
Cheers,
Si.
Same here, I can get several SIPs to work with my Nokia N95 but NOT plusnet.
How about some support on this issue PLUSNET!!!!
Fixes: 70
I can also get Truphone and Sipgate working with my N95 but not our Broadband Phone service. If I'm honest I'm not sure why this is.
Someone in the thread here managed to get it working after installing Truphone so it may be worth giving that a download and trying those settings.
There have also been suggestions that Noikia don't support the codecs we use.
Nokia support:-
G.711
iLBC
AMR-NB
G.729b
My ATA works when configured to use G.711 > G.72X so I'm not 100% sure this is the true cause. I dhall try and do some digging.
Kind Rgds,
Plusnet Products Team
Bob,
Have you had any progress on this? I have tried everything I can think of on my N95 and cannot get it to connect to plustalk. I've installed Truphone and that works fine, so bacially at a loss at the mo!
Cheers
Fixes: 70
I have tried to find out but the engineer who helped build the platform (one of them has since left the company) is on holiday for 2 weeks Sad
We do have a longer term plan to improve the existing VoIP solution, install additional monitoring and ensure that it can managed/maintained operationally.
The work for this consist of 3 work streams which can run concurrently.
* Server upgrade
* VoIP end to end monitoring
* Provide resilience & failover
The Server upgrade work is likely to be started as soon as we can secure the appropriate engineers time. As a last resort we could make sure this will work as part of the upgrade.
Kind Rgds,
Fixes: 70
Morning all,
To confirm, PlusTalk actually uses the G711 ulaw (American), G.711 alaw (Europe) and GSM codecs so should work with PlusTalk.
Will continue to see if I can get to the bottom of things.
Rgds,
