Nokia 3310, help please
Hey,
I have a Nokia 3310, yes i know its old, but anyway, is there any way i can use msn messenger? in some way? maybe using sms? or something?
Thanks in Advanced,
Tim
It is not a WAP phone, so no.
But what about the sms feature?
all phones support SMS... it's called TXTing
Yes, you can use MSN via SMS.
Open MSN and goto Tools -> Options.
Select Phone
Click "Mobile settings".
Once you have completed the needed details, there should be a "View quick numbers" link.
Here, it will list the numbers you should text, for each of your contacts.
You can only use these numbers from the mobile number you used to register with.
Kooll!!!! Thanks, only problem is it costs money, is there a way around this?
Thanks, Tim
Err, no.
SMS has transport costs, do you think they are going to provide a service and pay for you?
