No incoming email into Outlook 2003
Hi
Anyone any experience of resolving problems with receiving e-mail into Outlook 2003. System works fine for outgoing e-mail. Also incoming e-mail arrives at host Mailbox but is not forwarded into Outlook.
I'm working with XP home, Netgear wireless cards and and ADSL router (DG834G using DCHP) on a small home network. Everything else is working fine. Been round all the help lines and each says theirs is working OK, its the others that must not be working. Have tweaked and retweaked the MTU, suspended virus checking on incoming e-mails, reinstalled everything, to no avail.
Bill
How do you know this?
Can you explain the steps you used (exactly) to find out ti was arriving./
By logging into the generic Mailbox on PLUS I can read all e-mail posted to all sub-addresses. However email that should have been forwarded to the sub-address set up in Outlook did not arrive.
Bill
Please remember, you know exactly what your problems are. We do not. As such, you need to describe in as much detail as possible, to give us some understanding.
As such, you need to give a description like the following.
1: Logged into webmail with the username hall242
2: Was able to read e-mail addressed to gary@hall242.plus.com
3: Opened Outlook 2003
4: Wouldn't download e-mail from account username hall242+gary
