Newsgroup 'empty' (Adobe)
beskar
Hi - using dial up Pipex can see messages from Adobe newsgroups (e.g. adobe.acrobat.windows or adobe.acrobat.capture no problem.
With Plus ADSL, they continually show as empty (same newsreader, OE6, fully patched).
Can get other some NGs on Plus e.g. uk.telecom.broadband etc.
Any idea why? Fed up having to use dial up to access the other ones.
p.s. there is a reference in the Help pages to MyNewsReader facility for online ng checking via portal - but can't find link to facility.
Understand "MyNewsReader" as USENET and then use the search option to search for Adobe newsgroups.
They all come up with no messages for me, too.
I think you should raise it with support through Contact us.
beskar
Thanks - wanted to check in case it was me doing something dumb!
