Newbie Domain help
Newbie Domain help
HI!
I have a co.uk domain name registered with plusnet,I would like to point it towards another free plusnet webspace account.
I have spoken to plusnet technical support on the phone who said they dont support this kind of enquiry who mentioned something about framesets but since I am a total novice I dont know how to set it up.
If that doesnt work my other alternative is to share the 250meg webspace I have with another .co.uk website which is pointing towards my plus.com space,what is the step by step process to do that?
Anyone?
1 REPLY
Newbie Domain help
With regards to the first solution, using frames - check out www.moonphase.plus.com that will tell you more or less what you need to know, although its not the frontpage server you are pointing at its the free account you are using. Its a messy process though and search engines dont like it and neither do many people looking at the site.
The second option is easier. Read the tutorial in the tutorials forum on how to do it.
Chris
