Netgear DG834 VPN
Netgear DG834 VPN
Has anyone successfully set up a working VPN connection using Windows XP VPN Server and a Netgear DG834? I keep getting Error 721, it simply does not authenticate. Help! Cry
Netgear DG834 VPN
What MTU are you using, as I've read somewhere that lowering can sometimes do the trick.
Aaron
Netgear DG834 VPN
Yes, I read that too somewhere. It was something about the packet header being too large. :shock: My MTU is 1478. Any suggestions as to how much smaller to reduce it to?
Netgear DG834 VPN
Hmmm, good question really, Try 1450 or 1420 , just remember to adjust your PC and all the settings around it as well.
Aaron
Netgear DG834 VPN
1458 & 1430 are the more common settings and don't forget to adjust your RWIN to match. See MTU tweak.
Netgear DG834 VPN
I've tried all sorts of combinations, nothing seems to make a blind bit of difference. Cry I still get Error 721: The remote computer did not respond.
Netgear DG834 VPN
Are you running any firewalls?
Disable any software firewall and if running XP, disable the windows firewall as well and see if that helps.
Netgear DG834 VPN
I have already disabled software firewalls, I have opened Port 1723 on my router, according to the logs it forwards the packets to my machine, but the VPN software (courtesy of Microsoft) doesn't respond.
Netgear DG834 VPN
Ideally, I need to know values of MTU and RWIN which work on somebody else's computer who has got VPN working, so that I can eliminate this possible cause.
Netgear DG834 VPN
Any Joy? I've not used a VPN but I will be soon for connecting into work. I'll ask a few guys from the computer room in work who setup the laptops to work with VPNs if the have any ideas.
Aaron
Netgear DG834 VPN
Nope, it's still a complete mystery. The router is forwarding the packets to the correct client, according to the router logs, but the software (MS VPN Server) doesn't respond. Cry
Netgear DG834 VPN
Could it be a problem at the other end? rather than with your machine?
Netgear DG834 VPN
Possibly, but I doubt it. I shall ask our tekkies if they block incoming VPN packets.
Nice avatar, by the way, gadgetboy!
Netgear DG834 VPN
Hi could be their firewall is only set to allow connections on certain ports, or certain IP addys. From what you have said I can't see much more than you can do really.
Thanks lol
Aaron
Netgear DG834 VPN
Well, Netgear have told me that they are sure it is not the router which is at fault. In fact, if I log any outgoing VPN packets, none are logged. So the Microsoft VPN Server software is not responding. Could be an XP SP2 issue!
