My Forum
michaelscott
My Forum
oh cool, it's online now! Cheesy
My Forum
By the way i just set up a forum on my computer, check it out, at http://80.229.33.172/phpbb2/index.php Tell me what you think and tell me any problems you find Sad , thanks tim
michaelscott
My Forum
it doesn't load. perhaps you should try leaving your computer on and connected to the internet?
My Forum
phpBB : Critical Error
Could not connect to the database
is all I get.
My Forum
Well, the web server is but not the forum. Still get the above error.
My Forum
Ok, i just got it up again, only the forum is up tell what errors you find.
Tim
[Moderators note (by Thomas): Stray quote tag removed for you.]
michaelscott
My Forum
I don't know what you want us to say. As long as it was installed correctly we should encounter no errors. As it stands, it's just a plain phpBB installation using the boring default theme.
My Forum
Could someone registrar and see if thats working?
michaelscott
My Forum
no, it isnt working. you do not have php configured correctly so it can not send me the activation e-mail.
open C:\WINDOWS\php.ini
look for [mail function]
make sure SMTP looks like the following:
SMTP = relay.plus.net ; for Win32 only
My Forum
Ok Changed it could someone try again please, this is greatly appricated
michaelscott
My Forum
nope, same problem. copy and paste that section of php.ini plz
My Forum
[mail function]
; For Win32 only.
; For Win32 only.
sendmail_from = boredom281@yahoo.com
also its called php.ini-dist in the php folder
michaelscott
My Forum
[mail function]
; For Win32 only.
sendmail_from= boredom281@yahoo.com ; for Win32 only
^ copy and paste that. i think that you only need to edit c:\windows\php.ini
My Forum
i will but i just changed some more things i realized mite be the problem could u just cheack to see? thanks
Jim
My Forum
Change the php.ini file as described above, then in the admin control panel/configuration screen
change the e-mail settings to
Use SMTP Server for email......Click Yes
SMTP Server Address..............relay.plus.net
SMTP Username............leave blank
SMTP Password..........leave blank
This works for me Smiley
Jim
