Msn messenger
Msn messenger
Is anyone else getting disconected from msn every few mins? it only seems to effect msn though, IRC is fine.. i have no idea what could be doing it.
Msn messenger
Firewall ?
Antivirus?
Router?
Msn messenger
yes
yes
yes
it was fine up untill like a week ago(as in fine for 3 years), then it started to piss up.
version 7.5 btw (latest build)
FooAtari
Msn messenger
I haven't had any problems...
Maybe ports are being blocked?
You could try Messenger Live (version 8 i think?) I use it and have had no problems.
Msn messenger
see I know my setup is fine, its *not* getting blocked as it WORKS and i own the router et al in question, it WORKED fine with no change in setup, Guess its just my line being ubergay seein as msn is quite sensative to that kind of thing.
mods you can close.
