Member Centre and IE7
Just noticed that none of the pages in the "My Account" section appear in the Member Centre when you are using IE7. I know it's a beta product, but this is the only web site from hundreds that I have tried, including some complex web based business applications that hasn't worked properly.
1 REPLY
shellsong
Which beta are you using? If it's beta 2 try beta 3 which apparently has sorted IE's problems with sites like the PN one-- personally I only use IE if there's nothing else to do the job! :roll:
