MSN Problems
MSN Problems
For the last few days, my mother-in-law has been unable to access the MSN service from her connection. The MSN connection checker reckons that key ports are blocked. So far I've temporarily removed the firewall and still had no luck before re-installing it.
Are there any restrictions on IM with the Plus packege I wasn't aware of?
MSN Problems
Nope, none of the ports IM uses are blocked by PlusNet.
LiamM
MSN Problems
All working OK here. I would suggest checking your system for spyware / viruses etc...
