MS Exchange
MS Exchange
What i want to do isset up my own mail server. At the min my conection goes to my firewall server(MS ISA) then this is networked to 2 other servers one as a DC/File server and another running MS exchange. All 3 servers are on the internal network IP 192.168.x.x. Will i be able to set up the SMTP feed so my exchange server gets the mail as its not the server conected to the internet .
Many thanks
Chris
MS Exchange
I assume you have two nics in the isa server one facing the web and the other internal? Or do you have one nic and a adsl modem?
If you have a modem then you just setup the isa server to let traffic through to exchange. If you have a router before the isa server and 2 nics you may have to port forward on the router as well.
It should all work fine as its desgined to work that way.
MS Exchange
The ISA box has one internal nic and one adsl modem, the internal nic goes to the hub . Conected to the hub is the DC server and the Exchange server and the client machines aswell. running 2003 server, isa 2000 and 2003 exchange. Will it be a case od setting the MX records in the plusnet config with the A records to point to my ISA server then let it resolve the location of the exchange server from there..?
Many thanks
Chris
MS Exchange
yes you set the record to your fixed ip and the server should sort it out
