MP3 Converting software
rja66
I know there are lots out there but can anyone recommend some 'free' software to convert audio files to mp3?
I would like to be able to rip a track from a cd (which i currently do in media player to play on my pc) convert to mp3 so that they can be used as a ringtone.
Thanks in advance. Smiley
windows media player can do it, as can CDeX.
rja66
Thanks, however windows media player appears to require an mp3 encoder to be installed which you have to pay for (despite microsoft stating mp3 encoding support is included at no cost with Windows Media Player 10) :?
Rich
Get a copy of Audacity from http://audacity.sourceforge.net/
You will also need to download an encoder dll (LAME MP3 encoder - there's a link on the web site).
Best of all - It's all free! and is available for Windows 98, ME, 2000, XP or later, Mac and Linux.
From the web-site -
About Audacity
Audacity is a free, easy-to-use audio editor and recorder for Windows, Mac OS X, GNU/Linux, and other operating systems. You can use Audacity to:
* Record live audio.
* Convert tapes and records into digital recordings or CDs.
* Edit Ogg Vorbis, MP3, and WAV sound files.
* Cut, copy, splice, and mix sounds together.
* Change the speed or pitch of a recording.
* And more! See the complete list of features.
CDeX!! Smiley
holdtight
yeah ive always used cdex its far better than most others ive tried
rja66
Thanks for the advice, i'll give 'em a try!
