Login Failed! Contact Network Admin
me too :-( i've contacted tech support to no avail.
i have a bt voyager 2110, and kerio personal firewall.
any suggestions greatfully recieved.
XP Pro is the OS - Fully patched :-)
Christopher Miller
I Signed up for plustalk yesterday and can't see to get it working.
All I get is "Login Failed! Contact Network Admin"
I have double and trippled checked the settings in x-lite config menu.
I have punched holes in my firewall (netgear DG834G Firmware Version V3.01.25 ) for
SIP (UDP) 5060 - 5070
STUN (UDP) 3478
RTP (UDP) 8000 - 8001
I have even tried dropping the firewall on the router and my windows box.
I have tried using my Mac iBook which gets the same result.
An Ethereal trace reveals last packet I get is
SIP - Status:407 Proxy Authentication Required
mog0
I signed up today and I am having exactly the same problem. I am also using a Netgear DG834G router but with firmware v3.01.29. I have also set up the NAT rules that you mentioned and I also get "Login failed! Contact Network Admin."
Mog
They seem to have fixed it now! Smiley
mog0
Fixed for me too.
Moxham
Can you tell me where you got firmware v3.01.29 from. I cant seem to find it. Any advantages on firmware v3.01.25?
Antarchie
not here :-( :-( Still not working :-(:-(
mog0
Moxham
Antarchie
I would have got it from the netgear support site but having checked myself like you I can only find 3.01.25 on the site. When I view the Router status page on my router it displays 3.01.29. I don't know what the difference is. It's possible that Netgear have withdrawn it due to problems but I'm not aware of any.
Sorry can't help any more than that.
Mog
