'Login Failed', '407 Proxy Error'
Hi, I recently signed up for the 'anytime' plustalk package, however the softphone i use (x-lite) gives me the message 'Login failed, contact netowrk admin', i have raised the issue with the plusnet customer suport team and they dont seem to know why its doing this, i have followed the setup page word for word and for a while it did work. any ideas?
thanks
i dont know how much you have gone thru with the CSC, but have you tried using it with your firewall disabled.
On boot, X-lite should give a message somthing like discovering firewall then the proxy login should be discovered an after that successful login should ocurr.
Initially it sounds like a firewall issue either software or hardware based.
Thanks, The firewall on my computer and modem/router is dissabled, i have contacted customer support 3 / 4 times about it now and i have heard nothing, i have also tried reinstalling the x-lite softphone, i went thru the setting in the menu as i was on the phone to an adviser and i still have had no luck..Sad
any ideas?
With the X-lite software running on your desktop, press your F9 key on the keyboard and that will bring up the log.
Copy and paste the log here and we'll have a look.
Verify also that your username and password are correct and are using the correct case.
Hopefully the log will give some indication of where the problem lies.
Plusnet Staff
Plusnet Staff
I don't know what the problem is, but I've been able to replicate it so it's somewhere our side. I've sent a ticket on to the VoIP gurus on our side to look into it for you.
Hi, Thanks... i didnt know how much of the log to copy and paste so i copied most of it... here it is...
© 2005 CounterPath Solutions Inc. All rights reserved.
X-Lite release 1105x build stamp 21407
License key: FB4BDABEE0AB4CE383211D122E3D194C
Established SIP protocol listen on: 10.0.0.5:5060
Discovered Full Cone NAT Firewall
SIP: 10.0.0.5:5060
RTP: 10.0.0.5:8000
NAT: 84.92.143.54
PROXY#0: 84.92.5.189:5060
PROXY#0: 84.92.0.75:5060
PROXY#0: 84.92.0.76:5060
PROXY#0: 84.92.5.190:5060
SEND TIME: 93737273
SEND >> 84.92.5.190:5060
REGISTER sip:howe373.plus.com SIP/2.0
Via: SIP/2.0/UDP 84.92.143.54:5060;rport;branch=z9hG4bK8CA69E165B4A40DDBBA5FF4381E8ADE4
From: Daniel Howe <sip:208441@howe373.plus.com>;tag=3455517114
To: Daniel Howe <sip:208441@howe373.plus.com>
Contact: "Daniel Howe" <sip:208441@84.92.143.54:5060>
Call-ID: 4C35AF38ABA246E1B43F32BD54203B44@howe373.plus.com
CSeq: 32264 REGISTER
Expires: 1800
Max-Forwards: 70
User-Agent: X-Lite release 1105x
Content-Length: 0
RECEIVE TIME: 93737324
RECEIVE << 84.92.5.190:5060
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.0.5:5060;rport=5060;branch=z9hG4bK8CA69E165B4A40DDBBA5FF4381E8ADE4
Server: Plusnet-SIP Router (0.7.2 (i386/linux))
Content-Length: 0
Warning: 392 84.92.5.190:5060 "Noisy feedback tells: pid=16032 req_src_ip=84.92.143.54 req_src_port=5060 in_uri=sip:howe373.plus.com out_uri=sip:howe373.plus.com via_cnt==1"
RECEIVE TIME: 93737327
SIP/2.0 407 Proxy Authentication Required
To: Daniel Howe <sip:208441@howe373.plus.com>;tag=1d5db9f8d42fd00c7c4d2421577a533b.08f3
Proxy-Authenticate: Digest realm="howe373.plus.com", nonce="43ef490d89c79fcff460b0ffd24daa6900ed67d0", qop="auth"
Content-Length: 0
SEND TIME: 93737330
Via: SIP/2.0/UDP 84.92.143.54:5060;rport;branch=z9hG4bK88BA32B1D63D4E34A0AF34B0DA9AEA89
CSeq: 32265 REGISTER
Expires: 1800
Proxy-Authorization: Digest username="208441",realm="howe373.plus.com",nonce="43ef490d89c79fcff460b0ffd24daa6900ed67d0",response="13e8b1721cb86dc6472d95c7c196a040",uri="sip:howe373.plus.com",qop=auth,cnonce="B444BA880DB543E09FB759E61342A0D5",nc=00000001
Max-Forwards: 70
Content-Length: 0
RECEIVE TIME: 93737386
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.0.5:5060;rport=5060;branch=z9hG4bK88BA32B1D63D4E34A0AF34B0DA9AEA89
Content-Length: 0
Warning: 392 84.92.5.190:5060 "Noisy feedback tells: pid=16031 req_src_ip=84.92.143.54 req_src_port=5060 in_uri=sip:howe373.plus.com out_uri=sip:howe373.plus.com via_cnt==1"
RECEIVE TIME: 93738681
To: Daniel Howe <sip:208441@howe373.plus.com>;tag=1d5db9f8d42fd00c7c4d2421577a533b.7486
Proxy-Authenticate: Digest realm="howe373.plus.com", nonce="43ef490f3f24572aa0cf8e99056d393c35e8109b", qop="auth"
Content-Length: 0
csogilvie
You appear to be using the wrong username. The username for authentication should be 'plustalk' but you appear to be using your SIP id.
thanks but i have tried plustalk... but the customer adviser told me to try my SIP ID... either way it doesnt work with any of them.
csogilvie
You should definetly be using plustalk...
What do the logs say if you use "plustalk"?
This may seem a stupid question, but you are using your correct password?
What STUN server have you got configured for your voip phone to use?
Nick_Russell
I use Voipfone and had a similar error. 407 error could be wrong user name or password or proxy server problem.
Simple solution for me was to add an entry in NAT field. For me it was to use the setting "Outbound proxy = nat.voipfone.co.uk:5065". Don't know what PlusTalk's settings will be but I guess similar.
I assume you have SIP Port = 5060?
domcaz
sme problem
I have the exact same problem as Howe...
Anyone found a solution yet?
Thanks,
Dom
same here just signed up initially said error 407 now just says Login failed contact Network admin
my log
License key: FDB16141A510406CA81DFA1AB215E2E2
Established SIP protocol listen on: 80.229.252.97:5060
Discovered Restricted Firewall
SIP: 80.229.252.97:5060
RTP: 80.229.252.97:8000
NAT: 80.229.252.97
SEND TIME: 3005091
SEND >> 84.92.0.76:5060
REGISTER sip:johnss99.plus.com SIP/2.0
Via: SIP/2.0/UDP 80.229.252.97:5060;rport;branch=z9hG4bK007610800DCA4818B77D857A848A76A3
From: johns99 <sip:plustalk@johnss99.plus.com>;tag=3818145643
To: johns99 <sip:plustalk@johnss99.plus.com>
Contact: "johns99" <sip:plustalk@80.229.252.97:5060>
Call-ID: BE904F4B76954DEBA2C1FBB4E186CAFE@johnss99.plus.com
CSeq: 6738 REGISTER
Expires: 1800
Max-Forwards: 70
Content-Length: 0
RECEIVE TIME: 3005125
RECEIVE << 84.92.0.76:5060
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 80.229.252.97:5060;rport=5060;branch=z9hG4bK007610800DCA4818B77D857A848A76A3
CSeq: 6738 REGISTER
Content-Length: 0
Warning: 392 84.92.0.76:5060 "Noisy feedback tells: pid=4375 req_src_ip=80.229.252.97 req_src_port=5060 in_uri=sip:johnss99.plus.com out_uri=sip:johnss99.plus.com via_cnt==1"
RECEIVE TIME: 3005130
To: johns99 <sip:plustalk@johnss99.plus.com>;tag=5f540b84c666d3bb8d61b46499111ad5.c387
CSeq: 6738 REGISTER
Proxy-Authenticate: Digest realm="johnss99.plus.com", nonce="4432dfdb871ca7da40d42f76f5c462b2476cf916", qop="auth"
Content-Length: 0
SEND TIME: 3005132
Via: SIP/2.0/UDP 80.229.252.97:5060;rport;branch=z9hG4bKE2B5EADE13CB40E2B59ADAA731A55972
CSeq: 6739 REGISTER
Expires: 1800
Proxy-Authorization: Digest username="plustalk",realm="johnss99.plus.com",nonce="4432dfdb871ca7da40d42f76f5c462b2476cf916",response="472dcde77f1c7921c99267ee9781f301",uri="sip:johnss99.plus.com",qop=auth,cnonce="C07D582CB6864FB7A334479C49C4528D",nc=00000001
Max-Forwards: 70
Content-Length: 0
RECEIVE TIME: 3005172
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 80.229.252.97:5060;rport=5060;branch=z9hG4bKE2B5EADE13CB40E2B59ADAA731A55972
CSeq: 6739 REGISTER
Content-Length: 0
Warning: 392 84.92.0.76:5060 "Noisy feedback tells: pid=4371 req_src_ip=80.229.252.97 req_src_port=5060 in_uri=sip:johnss99.plus.com out_uri=sip:johnss99.plus.com via_cnt==1"
RECEIVE TIME: 3006217
To: johns99 <sip:plustalk@johnss99.plus.com>;tag=5f540b84c666d3bb8d61b46499111ad5.db37
CSeq: 6739 REGISTER
Proxy-Authenticate: Digest realm="johnss99.plus.com", nonce="4432dfdc63de5ad8922a427a0c60fd0316f29664", qop="auth"
Content-Length: 0
Thanks a lot in advance for any help!
Having the same problem here
Can not log in either contacted support who said there is are issue with Plustalk and their engineers would be working on it shortly, that was 2 days ago so as I am new to plus net I do not how long "shortly" is with them,
Even my 0845 number will not work so there must be something down along the line.
shortly means today or in the next 6 months!
