Local Rate Number
Local Rate Number
Have just signed up for the £2.99 offpeak tarrif on plustalk, but when I try to register a local rate number to use with it - all I get is a blank box where it says my number should be...
Any ideas?
Marc Cheesy
Local Rate Number
Also, can anybody confirm that USB phones will work with PT?
I am setting up a small business venture to fund my studies, and would like to use PT as my telephony service, however a proper handset would be essential - and I can only afford a usb one
Local Rate Number
i have got a usb cyberphone k that works great with x-lite, so long as you get the version of x-lite that supports the phone Smiley
Local Rate Number
which version of x-lite do i need?
Thanks for the advice
Local Rate Number
i can send you the web link in a pm if you like?
Local Rate Number
Yes, Please. I would really appreciate that... Cheesy
Local Rate Number
you should have a message Cheesy
Local Rate Number
I have Thankyou Cheesy
