Listening to voicemail
Is there any way of listening to voicemail from a normal landline. Getting an email notification is great as I get the email on my mobile however not being able to check the voicemail is then very frustrating.
1 REPLY
Pendragon
Just a thought, if you can get email on your mobile can you also use a web browser because it seems possible if you can, to listen to your voicemail on your mobile. This is from part of a help page;
1. Broadband Phone Control Panel
Login to the Broadband Phone control panel
Click on the Voicemail tab
Click PLAY on the relevant message
To remove a message click DELETE.
As I said I don't know if this will work but otherwise from a landline I think the answer is no, regards, Colin.
