Linux for internet
Linux for internet
I got a free copy of Knoppix Linux 3.4 with a magazine and I thought I might set my system for a dual boot so that I could use Linux for browsing and e-mail, and use Windows for other applications. From what I can make of the documentation, the version of Lixux I have does not support USB ADSL modems which is what I have.
Can anyone suggest a version of Linux that would be suitable for my requirements and is reasonably simple to install?
Or can I use the Knoppix version I have and download some sort of add-on that would allow me to set up my USB modem?
lowry
Linux for internet
USB modems require software drivers to function and the vast majority only support Windows. The USB ADSL modems that have Linux drivers are often unreliable at best, so I would recommend purchasing a wired or wireless-capable ethernet ADSL router.
This would mean that you could just connect the router to the ethernet network card in your computer and there would be no requirement of software drivers.
Try BroadbandBuyer, DSLSource, Amazon and EBuyer for ADSL routers. Watch out that you get an ADSL router modem and not a 'Broadband Router' (these have no built-in modem and so are practically useless to most people).
matt Wink
Linux for internet
Hmmm It looks like this would be a rather costly option. I had my computer made to order and it doesn't have an ethernet card as I never expected to need a network connection. I'd have to buy that plus a router.
lowry
Linux for internet
An ethernet network card would cost less than a tenner from most online retailers. Plus, you could get a cheap wired 1 port router for less than £35 from the sites I have mentioned.
matt Wink
Linux for internet
I think they will work in the latest 2.6 kernal, as the USB support is getting a lot better, however, an ethernet router is a far better choice as it reduces the load the CPU has to do, thus makes your PC faster, as well as more secure as they nearly all have an added firewall option
Linux for internet
matt Wink
http://www.ebuyer.com/customer/products/index.html?rb=5493163707&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3... 4 port for under £25
Linux for internet
Thanks for the suggestions, folks - I'll look into it further.
