Kerio Firewall to be discontinued
Hi All,
For those who use the firewall, and don't yet know. Kerio is to be discontinued.
http://forums.kerio.com/index.php?t...0cc6fa8dc15787d
Ohhh Nooooo! I really like it.
shame :p
bigup sygate!
Andy, I think you need to reconsider your last statement, since sygate has been brought out by symantec.
lol
Well gadgetboy, what are you going to use? Zone Alarm? Sygate? Outpost? or do you pay?
I'm currently trialling the latest version of Zone Alarm Pro, and it seems good, but I'm slightly put off by the cost. Normally I use Jetico.
Is it good? is it free?
Jetico is free and it's very good, but and there is always a but, it depends on how comfortable you are with firewall rules.
Jetico creates expert rules for ever application, and thus it's much more involved that many other firewalls. You can just say I want to allow all for a particular application, but it's often better to control it with detailed rules.
If that doesn't sound your cup of tea, then there are some other good free firewalls I can recommend.
holdtight
How detailed are the log reports in Jetico Aaron ?
Cheers.
how to get the best firewall
1) get old pc you have
2) install openbsd
3) install iptables
4) sorted
or you could not care about the father company and use sygate Cheesy
Hi Holdtight,
They are very detailed, and also give you all the packet level info as well.
2) install openbsd
3) install iptables
4) sorted
How old can it be? Anyone know where you can get an ISA network card?
What are the specs on your PC? OpenBSD / Linux can run on many machines so it's a good way to use old machines.
However if your already connected via a router, then for most people this will provide enough protection.
Finally configuring linux firewalls is more tricky since you need to know the actual ports and rules you want to add but if your comfortable with that, then they are very secure.
i have 2 isa network 10mbit cards if you want them Wink
you can run openbsd and iptables on a 200mghz box if you want with 16meg ram and it will be fine
Older than that, it's a 486 ;-)
