Just Wondering
Just Wondering
Hi All
It's been a number of years since I have had one,but are there any security issues to be considered now before getting a fixed IP?
Ian & Linda Jordan
Just Wondering
yes
It does mean that your cp is live on the net with the same ip all the time so any attacker knows were to find you etc. If you are using adsl getting a router is the safest bet as it masks your real ip.
Just Wondering
Thanks for the feedback.however I will need to give it some thought,because it seems that if I wish to connect from multiple CLI's then a static IP is required if I read the page correctly.By the way I spent a fascinating few minutes trying out the security checks on your website.
Ian & Linda Jordan
Just Wondering
I don't see where you got the information from, stating you need a static IP for multiple CLIs.
A static IP, means you get the same IP each an every time your connect, no matter whyere from.
Dynamic IPs means a different IP each and every time.
Nothing more or less.
Just Wondering
You do need a static IP for using mutiple CLIs on FRIACO.
There are advantages and disadvantages to both dynamic and static IPs these are numerous and varied. I wouldn't say there is a major security risk in using a static IP.
Chris
Just Wondering
Connection settigs/CLI number...... I quote "If you have a Dynamic IP you will only be able to connect from your Primary CLI. If you have a Static IP you will be able to connect from up to 5 different CLIs, but only one at a time" end quote
Ian & Linda Jordan
Just Wondering
Ah, a +net thing.
I hadn't needed this with other ISP's
Just Wondering
It's to stop people multilinking the connection and hogging ports.
Don't forget its a X:1 contention rather than x:x (if you see what I mean).
Chris
