JavaScript Caching (or not, as the case may be)
Just a quick question: if someone goes to a webpage, which contains a JavaScript file, then goes to another webpage that uses the same JavaScript file, will Internet Explorer (or whatever browser the person is using) insist on downloading the .js file again, or will it use the one in the Temporary Internet Files?
Thanks in advance,
Thomas
csogilvie
It should send a request with the last modified time stamp and if the server supports it, it should send a 200 OK or a 304 Not Modified depending.
If you use Firebrid or Mozilla, theres a Live HTTP Headers extension that will reveal the headers.
Thanks - very helpful!
Thomas
