Java.Shinwow.BA Virus please help.
Denzil
Do a Google search on "java.shinwow" and you will get plenty of information and removal tools. From
http://www.microsoft.com/technet/security/bulletin/MS03-011.mspx
it seems to be a fairly old flaw that this thing tries to exploit. As long as you keep Windows updated regularly the potential for damage should be fairly small.
1 REPLY
Can anyone help me get rid of this virus (Java.Shinwow.BA)? It has been caught by my Zone Alarm, but only when i run Ad-Aware SE. It only gets picked up by Zone Alarm when Ad-Aware is run and Zone Alarm usually can not fix it.
I deleted the Ad-Aware querantine list and all system restore points in case it was hiding in them but it keeps coming back. Sometimes Zone Alarm fixes it then next time it cant.
I have followed the file path Zone Alarm gives to where it is but the file does not seem to exist. I cant even find it searching the pc search folders engine. But it keeps coming back.This is starting to do my nut in lol.Any help would be mucho appreciated. Thanks in advance.
