It’s a miracle.
It’s a miracle.
I am perplexed, :? while uploading my results from a qualification round for the game Americasarmy my firewall (Nortons internet security) informed me I was under attack. I looked at the IP address of the PC that had run a port scan on me and thought that looks familiar, ran a trace and was very surprised when :shock: “you’ve guest” it was my IP address and login name.plus.com.
Any ideas anyone.
It’s a miracle.
I'm guessing that your pc is infected with a virus, most of them (the virus')seem to be working on Lan's and ip's in the same range. So it went out on port say 2430 and in on 135.
It’s a miracle.
Are you sure it said your IP was attacking you.
Remember, there are two parties to a connection. The sender and the recipient will depend on the direction of data transit.
What IP, if any, does the firewall show as the second entry.
It’s a miracle.
Hi Goose and Philip
Goose, downloaded latest virus definitions and ran the scan, 1 found, a Verifierbug. Class what ever that is. Nortons has quarantined it, could not be fixed. I have sent it to symantec for analysis.
Philip, double double checked, the attack originated from my IP address according to the trace. I’m not sure, I think the second entry is 206.204.52.216.
Well its happened again I’ve attacked myself again tonight I think I will send myself an E-mail re these attacks and report myself to my ISP Smiley Ha Ha.
On a more serious note do U think I’ve miss configured my firewall, the virus done it or is it possible someone has assumed my net identity and is having a laugh. I did'nt think this was possible hence the title of this post. Hang on the virus is in jail, thats one suspect eliminated.
Thanks for the input guys, (assuming Goose is a guy of course, if not no offence intended)
It’s a miracle.
Update
Still running port scans on myself every time I connect to AA had a fiddle with the config to no avail. Had additional problems also, Autocad 2002 LT wouldn’t open at all and win98se hangs almost every time I shutdown and occasionally during start up.
When I uninstalled Nortons and the above seem to work fine. I have cured the cad problem with a patch from Autodesk site.
Beginning to think Nortons wasn’t such a good choice for my internet security. :x
It’s a miracle.
I have to agree there. The norton firewall installed on a friends machine is disabled every time the machine is rebooted. I'm no beginner but I cant find a way to stop it. Try zonealarm instead.
csogilvie
It’s a miracle.
I disagree... Norton Internet Security has been fine for me, is always active on rebooting and can be removed without rendering the internet useless.
It’s a miracle.
I used to use Norton, I'm convinced after 12 months useage of both, McAfee's product is the better.
Regards.
