Is it possible to run 2 X-Lite clients on PlusTalk?
Hi there.
I have two computers behind a router. I have installed X-Lite on them both with the intention of using ANY computer to receive or make a PlusTalk call (same SIP). Is this possible or supported? I seem to be getting some conflicts here..
Maybe its just the settings?
Anyone tried this?
Re: Is it possible to run 2 X-Lite clients on PlusTalk?
I'm not sure if you can do that or not, but you can run Asterisk on your computer and have that handle your phones.
Nick_Russell
I don't think you can have two computers logged onto the same VoIP account. To do this you have to use a virtual PABX and then each computer if effectively an extension to your VoIP account. I'm sure PlusNet do not offer this.
Try voipfone.co.uk.
http://www.voipfone.co.uk
Thanks for the replys. I will look into those options.
Where can I find out more about asterisk?
http://www.asterisk.org/
Also a search on these forum will show the configuration that another user has used to run an asterisk with PlusTalk
Good luck.
Chilly
