Is it possible to have two websites using my webspace
Hi
I wonder if it is possible to have two websites using my plusnet webspace, and if so how do I do it please.
Thanks Phil
If you host a domain with PlusNet (yourdomain.co.uk), then you can point it (www.yourdomain.co.uk) to a different directory from the basic PlusNet one (www.username.plus.com) - that way you can have more than one website.
Perhaps there are other ways too - I don't know.
oh right well I don't host a domain of my own just use the plusnet one given, is there no other way, anyone? Thanks
The only way I can think of would be to keep the two sites in seperate folders in your web space and refer to them by the folder names added to your username.
eg www.username.plus.com/first/ and www.username.plus.com/second/
If each of these sub directories contained a index.htm file then just calling up the names as above.
Ah ok John thanks I'll try that, hopefully it will work if not I'll look into getting a domain name.
Cheers
Phil
www.oneandone.co.uk - £1.99 per year, then transfer it in to PlusNet and your sorted.
