Instructions for Draytek 2600VG please!
I've got a 2600VG running firmware v2.5.7rc5_UK.
I'm unable to get it to work properly with the Plustalk service, although it *was* working OK a few days ago. Please can anyone fill in the correct settings for the fields as listed from the router below so I can ensure the basic setup is correct? (My settings currently in brackets). Many thanks:
SIP Port: (5060)
Domain: (myusername.plus.com)
Proxy: (sip.plus.net)
Outbound Proxy: (left blank)
Register via: (Auto)
Display Name: (Plus Talk)
Account Name: (SIP number e.g. 123456)
Authentication ID: (SIP number e.g. 123456)
Password: (usual Plusnet password)
Expiry time: (1 hour)
1 REPLY
prichardson
There are two methods to authenticate to the SIP server. One is providing a domain/realm of username.plus.com and the second is using your SIP ID in the process.
It would seem you are using a mix of the two methods.
The quickest method I can see to resolve your problems would be to set your outbound proxy to sip.plus.net.
The change "Account name" and "Authentication ID" to "plustalk".
Kind Regards,
