Incorrect web page??
I have just changed my DNS addresses to point to a new web space provider.
I have waited 48 hrs but when i go and check I still see the old web page.
I have had other people check this and they see the new page, some of these are on plus.net.
At first I thought it was a browser cache issue, but this is not the case as i have cleared it.
Any ideas appreciated.
Wayne
Can you confirm it is fully cleared though?
Have you tried a different browser? (eg Firefox over IE, or IE over Firefox)
Have you used CTRL+F5 to force a cache refresh?
Have tried CTRL F5 , still no look.
Have just downloaded Firefox and still the same result.
The page Iam trying to reach is www.digitx.co.uk
The page I see is the 1and1 holding page .
Wayne
If you see a 1&1 holding page, then it is most likely a cached DNS record that cached webpages.
If using Windows XP, click Start ->Run and type "ipconfig /flushdns" and try again.
Thanks for the info,
I am using XP and hae flushed the DNS records and still the same
I will leave it 24hr and see if works
Wayne
Incorrect web page
Is there any way that a web page can be encoded to enforce a refresh when the user looks at it from a cache? :?:
