Incoming PSTN via ZyXEL Prestige 2002L Analogue Tel Adapter?
This product looks great for enabling you to use an existing (normal) phone with the PlusTalk service. Looking at the spec, it also connects to the traditional phone line and automatically routes outbound phone calls that way if the VoIP service is not available.
As it is connected to the phone line, does this mean you can also receive incoming calls to that number from the phone you've plugged in to the adapter?
Is it a useable, practical option to use a single phone to receive calls made to your landline and dial-out over PlusTalk?
Thanks,
Pete
1 REPLY
According to the manual yes.
I can't however give this opinion as a user of the product.
