IPS Tag
IPS Tag
Is there any way of checking that an IPS tag has been changed rather than just looking at the WHOIS information for a domain ?
Our current ISP is claiming that they've changed the IPS tag, but I'd to be able to check!
IPS Tag
Other than using the whois system which should be updated with 24 to 48 hours afterwards (should be sooner), you could try contact who they claim they have transfered the IPSTAG too.
I beleive that in your circumstances, if they claim they have changed it, yet continualy have failed to do so (AKA, after a week or two and a few attampts), you can contact nominet direct.
You are best looking at the guides on the nominet site.
IPS Tag
Yeah, if you pay nominet £15 and have a good reason to do it, they'll change it for you.
Isn't all the ISP has to do is email nominet with their pgp key attached and state what they want the ips tag changing to ?
IPS Tag
It is is formatted e-mail, but yes. The system is automated.
It may be worth using the contact system on the nominet site. Changing your details because you want them/refusal is differant to them claiming it is changed.
Otherwise, you may be able to claim the £15 fee back in small claims court.
Alls well that ends well
Looks like this has been done (your domain import wizard worked anyway), many thanks
S
