IMAP and Opera
IMAP and Opera
I've just switched to PlusNet and had a little bit of trouble setting up Opera (version Cool to connect to access my email via IMAP.
The setup instructions are correct except that I had to change the incoming authentication to Plaintext instead of Auto, otherwise I kept getting an error message.
Just thought I'd post that info here in case anyone else has the same problem.
Cheers,
David
1 REPLY
imap and opera
Hi David,
I had the same problem but a different resolution.
all I did was change the username from domain+user to "domain+user" and everything worked perfectly !
Regards,
Paul
