IIS SMTP
IIS SMTP
I'm trying to use SMTP within IIS to send emails, but I'm getting the message "Your server has unexpectedly terminated the connection. Blah Blah", does anyone know a solution to this?
IIS SMTP
Check the server logs for IIS and the system logs to see if any service crashes occured.
IIS SMTP
Unfortunately, they don't really help, acarr. Sad
IIS SMTP
A quick look at link:Service Status may help clear things up. Wink
Thomas
IIS SMTP
Surely, using SMTP within IIS avoids using the ISP SMTP?? So, if PlusNet SMTP is down I should still be able to send emails!
IIS SMTP
Maybe you're right. I just saw "SMTP" and thought it might be connected! Smiley
Thomas
IIS SMTP
I think I have a possible solution. My current provider's DNS servers (my migration to PlusNet isn't till the end of the month Sad ) seem to be down!
IIS SMTP
All sorted now, just had to tweak the IIS SMTP settings, and now it works like a charm!!
