I Can't Receive Email From My Web Host
Hi
I have just signed up with Streamline.net for web/domain hosting and for some reason I cannot download mail from my new POP3 account on my home machines. I have tried 3 different machines and an iPaq and they all claim that the username or password is wrong - but they aren't.
The problem isn't caused by Streamline because my iPaq connection works fine when attached to my office network and I can link to my account at work using Outlook as well with no problem.
So the problem seems to be my home network somewhere. I have never had problems connecting to the Plus Net POP3 email. Does the fact that I am now using a different company make a difference? Could my router be blocking the ports for my new email server without affecting Plus Net's?
My router is a Solwise SAR110 and I did stealth the router a few years ago. I was wondering if that might be the cause of the problem?
I have no firewall software running on any of the machines so can anybody offer any advice/experience of this?
Thanks.
Streamline.net have a webmail which should work ok. Normally no isp will let you send mail if you are not logged onto their network as a antispam measure. Normally they will let you download mail ok.
If you are using outlook its normally in the advanced panel of the accounts setting were they have a tick box for the server requires a secure connection SSL. If this option is ticked it wont work. The exact menu differs on the version of out look but 90% of the time thats the problem
Sending mail isn't a problem, its just recieving and its only on my home machines, every other machine I've tried works fine, as does the webmail on my machines. SSL is not switched on.
I have tried to Telnet to the mail server from home and it connects but then rejects the password.
I have also found that its not just the email either the website itself can't be view from my home machines but can from my office and elsewhere. At home I get a 404 File Note found message which is strange because it looks like it is being directed somewhere but not the right place!?!
I leave Plus Net for BT today so I'm waiting to see if changing all the network stuff solves the problem. I've never come across anything like this before.
What you are saying sound like a spyware/malware type of problem or something strange in the host file. Have you check your host file and tested fro spyware?
I changed over to BT Internet yesterday and the problem disappeared, so it must have been something to do with my old Router but what is anybody's guess! :?
