Huntbar
Huntbar
Can anybody tell me how to remove a huntbar which has appeared on afriends pc. I have tried adware se and spy-bot without success. It is stopping them from accessing hotmail and slowing their pc down. Would changing browsers to opera for example help?
Any help would be gratefully appreciated.
Huntbar
change to firefox
www.getfirefox.com
and you should be able to unistall that bar in add/remove programs
Huntbar
Try http://www.spy-bot.net/HuntBar.asp
Note:I just did a google search for 'remove huntbar' and found many sites. If the above page does not work try searching ingoogle to find others.
Spybot & adaware can remove some but not all variants. Have you tried the latest 1.4 Beta2 version of spybot as that may have a better removal method. Just search for 'spybot beta' in google to find a download site for it. It'spretty robust and I have been using it for several weeks now without any issues.
