How to access my web space from my domain name
Hi to all
I've used Frontpage to develop a website, I've also had my webspace FP activated.
I have also tried to set up web page forwarding by visiting www.moonphase.plus.com
I have managed to FTP the files in accordance with the instructions at moonphase.
BUT, I can only access my site by using the standard http://fp.<usename>.plus.com address and not via my domain address ie. http://www.<domain name>.co.uk
Any ideas as to the problem will be gratefully recieved.
Thanks Shady
csogilvie
It appears as if you have uploaded the files from www.moonphase.plus.com to the FrontPage server as well as http://fp.efone.plus.com shows the Frameset page.
Thanks Colin
Sorry if this is a daft question, but what's the best way to rectify this?
csogilvie
You need to create the site you wish on the FrontPage server, and publish it so that index.htm contains the page you wish to view. This should then work fine.
Hi again
I just want to check that my Frontpage settings are correct.
I've got FP publishing to http://fp.efone.plus.net is this the correct server.
What's happening of course is that my new uploaded index.htm page is replacing the one put there under the directions of moonphase.com
I believe this could be wrong, am I right that the two files, index.htm and dummy.htm as supplied by moonphase, must stay on the server after all the only link to my domain is within that index file.
csogilvie
The files from moonphase.plus.com must stay on the WWW server (ftp.plus.net)
Your FP server is fp.efone.plus.com (NOTE: .com not .net)
Hi Colin
Pleased to say everything working fine now.
Many thanks for all your help
