How much does it cost to call a PlusTalk 0845 number?
Stef
Serious question...
JonathanW
The cost will be determined by your telephone company, and in the case of BT I beleive that its between 1pm and 3p a minute, depending on what time of day it is. The best advice would be to check with the company you use and ask how much it is to call 0845 numbers, as I know a couple of companies do charge a little more than BT.
Stef
Does anyone know typical rates from UK mobile networks to 0845...?
Ta, Stef
The one thing that I do know about 0845 is that it is not normally included in 'bundled free minute' type deals...
LiamM
Tis included in my bundled minutes. I'm with O2 Online.
Stef
Proves that I shouldn't believe everything I read on the Internet!
:shock:
lingbob
Daytime = 3p per minute
Evenings/Weekends = 1p per minute
Regards,
Martin
