How do I set my domain to point to plus cgi space ?
Domain Name Servers with Plus (ie I can add A, CNAME, MX via plus interface)
need to redirect www.evilc.com to cgi.evilc.plus.com
I set
left field : www
type: cname
right field: cgi.evilc.plus.com
what did I do wrong ?
I take it that it can be set up such that it shows www.evilc.com in the address bar and in the links and not the underlying cgi.evilc.plus.com address ?
left field : www
type: cname
right field: criticalmas.plus.com.
Note there is a full stop at the end of criticalmas.plus.com.
Once you have done this, raise a "Contact Us" ticket to PlusNet support asking them to "Change the CGI service to basic" this will create the necessary records on the CGI and DNS servers to correctly point the domain to your files on the CGI server.
All explained in Domains: Setting Up Domain records.
thanks
