How do I clean an XP sp1 machine that shuts down too fast
My nephews machine has become infected with the sasser worm (I presume). I've got the tools to remove it but he says it shuts down before windows starts and continually reboots. How do I run the cleaning tool?
try this while the timer is counting down
Start/Run
Type "shutdown -a" ENTER
Ian & Linda Jordan
I won't have time to look at it until tomorrow but from what he tells me it doesn't even get to the desktop. If hes mistaken I'll try what you suggest. Thanks.
There are instructions for the removal at...
http://www.microsoft.com/security/incident/sasser.asp
or a removal tool at...
http://www.microsoft.com/downloads/details.aspx?FamilyID=76c6de7e-1b6b-4fc3-90d4-9fa42d14cc17&displa...
If it really doesn't stay booted long enough to enter the shutdown abort command, then try safe mode.
have just recieved this from "F-secure",and must admit it means nothing to me,but someone may find it useful,and understand it
About the MS04-011 workaround
One sideffect of Sasser worm's spreading is that it crashes
LSASS.EXE which forces Windows to reboot. This makes it rather
difficult to fetch and install the required security patch.
A simple workaround can be implemented to prevent LSASS.EXE
from crashing. The following file must be created with Read-Only
attribute set:
%SystemRoot%\Debug\dcpromo.log
where %SystemRoot% is the Windows Directory (typically C:\WINDOWS
or C:\WINNT).
Since the MS04-011 vulnerability is in a debug print code,
if the debug log file can not be opened the vulnerable code
part will not be executed.
Hope it helps
Ian & Linda Jordan
Thanks for that. Can anyone remind me how you set 'read only attributes' from the safe mode command line?
attrib +r %SystemRoot%\Debug\dcpromo.log
