Hosting two web sites
thekitesociety
I currently have two domain names that I look after - currently hosted at seperate companies.
What I want to be able to do is move both of them to the free space on Plusnet but still keep them as separate entities for maintenance purposes. From a simplistic point of view I would have thought I could simply set them up under two distinct directories - eg:
www.me.plus.com/site1
www.me.plus.com/site2
I can then use webdiversion to send each site to the appropriate start directory.
Is this possible?
Yes what you describe is perfectly Ok.
Just put the files for each site into thier own directories in the htdocs main folder.
You can also setup each domain so it defaults to a directory on your www webspace as well. So someone entering www.domain1.co.uk will do directly to www.yourusername.plus.com/dir1 and www.domain2.co.uk will go directly to www.yourusername.plus.com/dir2.
See Domains: Setting Up Domain records for how to do this.
