Hoping for info
Ravinella
Hoping for info
Now that Plusnet are doing some form of VoIP, is it going to be possible to connect up something like Asterisk ( http://www.asterisk.org/ ) to the Plusnet system ?
Quite fancy the idea of having something like this running as a test bed.
Hoping for info
Billy,
I've got Asterisk able to receive calls from plustalk but as yet cannot get it to send/make calls without locking up my router (Vigor2600).
sip.conf:
[general]
<snip>
register => plustalk@<host>.plus.com:<acctpasswd>@sip.plus.net:5060/<local ext no> ;incoming from plustalk
[plustalk-out] ;outbound to plustalk
type=friend
host=sip.plus.net
username=plustalk@<host>.plus.com
secret=<acctpasswd>
insecure=very
dtmfmode=info
<snip>
On the asterisk console, type sip reload. Give it a couple of seconds and type sip show registry and it should show as registered (well it does for me).
extensions.conf:
<snip>
[plustalk] Grinial 7 to switch to plustalk
exten => _7.,1,Dial(SIP/${EXTEN:1}@plustalk-out)
exten => _7.,2,Playback(invalid)
exten => _7.,3,Hangup()
<snip>
Hope that helps. If anyone has managed to get asterisk to send calls over plustalk please post the various conf files!
Stuart.
Ravinella
Hoping for info
Brilliant, now I have some incentive to actually get on with setting it up, it'll give sparky (Sun Netra X1) something to do besides shift emails and wonder why I haven't gotten round to sorting out a website for the 2 domains she hosts.
In and out (ooer mrs)
Allrighty then, I've have a little time (and expense) and got Asterisk to make as well as receive calls Cheesy
The receiving config is the same as above....the sending bit is as below in sip.conf:
<snip>
type=peer
host=sip.plus.net
username=plustalk@<hostname>.plus.com
secret=<password>
qualify=yes
insecure=very
authuser=201*** ; Plustalk SIP number
dtmfmode=rfc2833
accountcode=out-plustalk
nat=yes
canreinvite=no
fromuser=plustalk
fromdomain=<hostname>.plus.com
</snip>
Hope that helps someone! Now let's see if I know anyone on Plus' peering arrangements!
Stuart.
/edit changed dtmfmode from info to rfc2833
Hoping for info
I've got Asterisk able to receive calls from plustalk.
What version of Asterisk are you using and can you still receive calls? I can make outgoing calls and asterisk appears to register ok, but attempts to make an incoming call just seem to be ignored completely by the plustalk servers.
Simon
Hoping for info
I've fixed my own problem: http://wiki.arlott.org/PlusTalk/Asterisk
